Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
MR62 Mesh and HP WiFi Printer
K9DAK
Hi all... I have an HP ENVY 5660 WiFi printer that refuses to work with my new MR62 mesh system.  Everything else on the network works perfectly.  If I unplug the satellite (located about eight feet from the printer), it works just fine; but when the satellite is connected, the printer often disappears from my PC, sometimes prints properly, and never allows me to scan a document from the printer to my PC.  Again, with the satellite unplugged, it works perfectly.  Is there any configuration on the mesh system I need to adjust for better functionality of the printer (subnet, etc.)?
Thanks in advance,
Dave
Message 1 of 3
Guru
Re: MR62 Mesh and HP WiFi Printer
Are you leaving the printer off the network and just connecting to it when you want to print?
If you connect it to the network, you can set it up as a network printer.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
K9DAK
No, it's powered on and connected to the network 24/7 as a network printer.
Cheers,
Dave
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 650 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
