Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Mesh WiFi 6 Router(MR60) & L2TP VPN via Synology
CmdrSolo
Follower
Just bought and installed the Mesh WiFi 6 Router(MR60) and am trying to configure the port forwarding for L2TP VPN service to my Synology Server. I believe I have the 3 ports configured correctly (500, 1701, and 4500); however, my remote device still does not want to connect. I have to believe the router supports passing the L2TP protocols through...any ideas?
UPDATE: Played around with some more settings and finally got it to work...the Nighthawk router sits behind my ATT Modem/Router that I configured as a Passthrough. However, I suspect that because the devices that sit behind the Nighthawk router technically reside on a different subnet, I had to redefine the port forwarding rules on the ATT router to point to the Nighthawk router - so I guess it essentially gets forwarded twice. Looks like everything is back to working order.
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Mesh WiFi 6 Router(MR60) & L2TP VPN via Synology
Hello,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 978 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
