Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Mr60
bdavis900
Follower
Mr60
Trying to find out why the xbox 1 are consistently connecting at under 10gb when all other devices are connecting at 100 gb +.
Message 1 of 5
Guru
Re: Mr60
A couple things.
1. you have the MR60.
2. what modem/gateway is it connected to?
3. What firmware is on the router?
4. is the xbox connected to the satellite or the router?
5. is it connected to the 2.4ghz or the 5ghz? (2.4ghz is slow)
6. are you sure you don't mean mbps and not gbps? (quite a bit of difference)
7. How are you testing speeds?
Message 2 of 5
Guru
Re: Mr60
Be sure to visit and post about this over in the NH MESH forum:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Message 3 of 5
Re: Mr60
Xbox stuff cauases constant problems. Another source of help could be a local search:
Search - NETGEAR Communities
Message 4 of 5
Guru
Re: Mr60
Any progress on this?
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1231 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
