- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NEW satellite pour système MK63 (config + Firmware + phone app
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello since a fiew months I have a MK63 system and it works great with 2 satelites
I wanted to add a 3rd satelite and since then I have some issues :
first I cant find any more the same firmware version of it in netgera site 😞
actua version : V1.0.6.102_2.0.45
requested Firmsare : V1.0.6.110_2.0.49
on the phone app I cant see my third satelite is this normal as I can from the modem config
thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NEW satellite pour système MK63 (config + Firmware + phone app
Hello Frost333,
If you're having issue on firmware v1.0.6.110 we recommend reverting back to firmware v1.0.6.102. We pulled firmware v1.0.6.110 due to an issue.
As for the app, you may need to reinstall the Nighthawk app.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
ok I have no rush to update the firmware as I have noticed too that netgear cam bach on this one
for the phone application I did already reinstall it but I think it is a limitation of the app du tu graphics as my third satelite is working fine juste that it is never showed on the app
maybe this will be taken in consideration as it could be useful
