- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NIGHTHAWK MK62 (MR60) 5Ghz setting for Nintendo Switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I have a problem that my Nintendo Switch can not connect to nighthawk mk62 using 5Ghz Channel. I have searched around, Nintendo Switch is support for 5Ghz connection but only using Channel 36 to 64 and 100 to 140. In my MR60, there are only few channels (36,40,44,48,149,153,157,161) can be selected. I can setup this in my pervious router (ASUS). Can anyone tell me that if it can be set in MR60 too?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NIGHTHAWK MK62 (MR60) 5Ghz setting for Nintendo Switch
Hello buddiz87,
The MR60 only supports specified channels and not a range of channels as you mentioned.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
In France, my MR60 router supports channels 1, 2, 3, 6, 8, 9, 11, 13, 44, 64, 100, 136.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Maybe by using the firmware for France, you could use the right frequency for your use:
https://www.netgear.fr/support/product/mk62.aspx#download
- Mark as New
- Bookmark
- Subscribe
- Permalink
In any case, you will be able to view all the content in English, if you wish, by changing the language.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Another possibility would be to choose the European region. To do this, connect to your router, go to Advanced, Advanced Setup, Wireless Settings, Region, and choose Europe.
