- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear MR60 mesh satellite routers steady orange
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good morning All,
I woke up this morning and found both of my satelite routers are no longer connected and show solid orange led.
I assume it tried to do a firmware update and had issues MR show ver1.1.6.122.
One satelite shows up but will not sync. Alot of my devices will connect to the main router and can route but some devices (apple iphone) will no longer connect to main router while other apple devices will connect.
Reset power and did factory reset on devices that shows up but does not connect.
Please advise of how I may resolve or troubleshoot further.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear MR60 mesh satellite routers steady orange
try factory resetting the satellites and then hardwire them into the router and sync them.
If its a firmware update, that should let them update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I reverted back to ver 1.0.6.116 on MR60 and MS60's I had to reconfigure SSID but satelite routers will still not connect after restart and sync. MR router is now allowing all devices to connect I am not sure how many revisions I need to go back to resolve. If anyone has had a similar issue and able to resolve please let me know.
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you try hardwiring in the satellites and sync'ing them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
does the 2nd one connect/work while hardwired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
and its on the same firmware version as the router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just FYI, if you seem to have problems with yoru MK system running on v122, you may need to revert back to v116. Were seeing other users post seeing lots of problems on v122 and NG is looking into it. So if you revert, please downgrade the MS first, the MR lastly.
