- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk MR62 Wired Backhaul
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
I have just purchased the Netgear MR62 Mesh System and having issues trying to get Wired Backhaul working.
I currently have it now setup in traditional mesh mode with the satelite connecting wirelessly just so i can use it but i would like to use Wired Backhaul. below is my setup
This is how i tried to get the wired backhaul working.
Nighthawk Router - Connected to managed network switch via "Internet" port on the back
Satelight - Connected to same managed network switch via Ethernet
Satelite would not show the backhaul connection in settings. Tried putting both in AP mode but this i think it not the right way
can someone explain in steps what i need to do
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk MR62 Wired Backhaul
What switch are you using?
what modem are you using?
When you have it setup is it going like this:
modem-----to wan port on router------>router-------->lan port------->switch-------->satellites
i've seen people use modem/router combo devices and go like this
modem/router-------switch------->wan port on router
Satellites
- Mark as New
- Bookmark
- Subscribe
- Permalink
How I imagined it could work would be
Modem/firewall to switch
Nighthawk router to switch
Satellite to switch
Is this not the case?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Again, a lot depends on how you have it wired into the switch. and how the switch is setup.
There's some conversations on managed switches.
https://community.netgear.com/t5/Orbi/ORBI-and-Switch/td-p/1672848
https://community.netgear.com/t5/Orbi/Orbi-Ethernet-Backhaul-with-Managed-Switches/td-p/1613897
you an also run into issues if the orbi is only connected to the switch via the WAN port.
It should go modem/firewall to wan port on orbi, then orbi connects lan port to switch with other devices connected to switch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
so to be clear.. the netgear nighthawk router needs a cable in the WAN port and the Ethernet port?
WAN port to my modem/firewall and Ethernet From the LAN to my Switch?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jmurphy19199 wrote:so to be clear.. the netgear nighthawk router needs a cable in the WAN port and the Ethernet port?
If you want everything functioning properly then yes.
modem/firewall----->wan port on nighthawk------>lan cord from nighthawk to switch
- Mark as New
- Bookmark
- Subscribe
- Permalink
No idea, and not much practical experience I'm afraid. So just wild guessing:
Operating Nightawk Mesh in router mode:
Modem/Router (bridged WAN) <-> [WAN] MR60 [LAN] <-> switch <-> [LAN] MS60
Operating Nighthawk Mesh in wireless access point mode:
Modem/Router [LAN] <-> switch <-> [WAN or LAN?] MR60 AP mode
or patch a dedicated link through the patch panel for the satellite connection
Modem/Router [LAN] <-> [WAN] MR60 [LAN] <-> patch <-> [LAN] MS60
The point mentioned in the thread before about Orbi/Orbi Pro (applicable to many other consumer Mesh systems allowing wireless or wired backhaul - because they use the Spanning Tree Protocol STP to discover the better path): One has to disable something very useful on a switch: STP, plus sometimes some more like disabling the ports from praticipating on STP. Even if one would configure a dedicated VLAN for the wired backhaul this would be required because this does work switch-wide, on all VLANs.
I think most of the active people here in the community don't have an official information what is required to operate the MR60/MS60 on a Smart Managed or Managed switch. @arunkmony please, your business! Don't understand why this is still not documented (or I can't find it...).
But then, with an environment in place @jmurphy19199 - I would not play with (read: stay far away from) consumer Mesh systems (except for learning and testing), and head to deploying wireless APs, e.g. Netgear Insight WAC540 ... not WiFi6/AX, but providing same if not more bandwidth over air than the AX1800 (600+1200) MR60/MS60 system.
