Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Netgear Prosafe GS108 and GS105 daisy chain for Nighthawk mesh MK63 ethernet backhaul
btv_94
Guide
ISP modem --->  MR60 --->  Netgear Prosafe GS108 ---> MS60
        I
        I
        I
                                               Netgear Prosafe GS105  ---> MS60
GS108 will have 4 desktop pc and 1 MS60 connected(Right side back of the house)
GS105 will have 1 desktop pc and 1 MS60 connected(Left side back of the house)
I have cat6 ethernet cable wired from livingroom where ISP modem located to 4 room toward back end of the house.
Will the above setup work on Nighthawk MK60 wired backhaul?
Thanks,
Message 1 of 3
Christian_R
NETGEAR Employee Retired
Re: Netgear Prosafe GS108 and GS105 daisy chain for Nighthawk mesh MK63 ethernet backhaul
Hi btw_94,
Were you able to test this out and if so, how did it turn out?
Christian
Message 2 of 3
btv_94
Guide
Hi Christan_R,
So far everything is working as plan (Ehternet backhaul). Setup took about an hour.
On right side back of the house where i have dead spot.  Wiht nighthawk RAX75, i can only connect 2.4 and getting 3-5mbps from my iphone.
With MK63 i now getting 220mbps everywhere inside the house. This router, sattellites and switch solved all the issues.
Thanks,
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1783 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
