- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New - MK8x series: MR80 / MS80 FW v1.1.6.10 Released
- Mark as New
- Bookmark
- Subscribe
- Permalink
Security Fixes: 11/29/2021
Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Download Link:
MR80 (Mesh Router) : https://www.downloads.netgear.com/files/GDC/MK83/MR80-V1.1.6.10_3.1.97.zip
MS80 (Mesh Satellite) : https://www.downloads.netgear.com/files/GDC/MK83/MS80-V1.1.6.10_3.1.97.zip
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To view your product’s user manual, visit https://www.netgear.com/support/product/MK83.aspx#docs.
Installation Instructions:
Download the firmware to a convenient place such as your desktop.
Log in to the router using http://routerlogin.net
Click the ADVANCED tab.
Click Administration.
Click Router Update.
Click the Manual Update tab.
Select satellite first and a new web page pops up. Please browse the new satellite firmware and upgrade satellite firmware first.
After you finish the satellite firmware upgrade, please find “Locate and select the upgrade file on your disk” on the MR60 web GUI and click “Browse” and locate the file you just downloaded.
Click Upload. While the firmware is loading, do not interrupt the upgrade process.
The router reboots when the upgrade is complete.
After the router boots up and the LED becomes steady blue.
To check that the upgrade was successful, log in to the router again at
http://routerlogin.net and check the firmware version.
Note: If a problem is seen after applying this FW update, try powering OFF the ISP modem, MR and MS units for 1 minute then back ON. Last resort would be to try a full on Factory Reset and setup from scratch.
This article applies to:
Let us know how it works for you in this thread...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - MK8x series: MR80 / MS80 FW v1.1.6.10 Released
Can someone check the download files?
Can't seem to upgrade it. Tells me the file is not compatible. I have tried downloading multiple times to ensure it was not corrupt. I have MK83 setup with MR80 and MS80. When I manually upgrade the MS80s I get the following error:
Failure |
This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product. |
This screen will automatically return to the previous screen in a few seconds... |
- Mark as New
- Bookmark
- Subscribe
- Permalink
What broswer are you using? Try MS Edge or Firefox?
I presume you are unpacking the .zip files as well?
Failure
This screen will automatically return to the previous screen in a few seconds... .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried Firefox, Edge and Chrome. All three fail with the same error.
Open to other ideas.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, sorry about that. I passed this on to NG for review. Hoping they will figure it out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
New FW for the MK80 series released:
