Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
New - MR80 / MS80 Firmware Version 1.1.7.12 Released
Guru
Security Fixes: 10/20/2022
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security/.
Bug Fixes:
  • Fixes the issue where the router web GUI cannot be accessed when DoH is enabled.
  • Fixes the issue where Internet bandwidth does not respect the router’s QoS settings
  • Fixes the issue where the router only allow 62 DHCP reservations
  • Fixes the issue where NETGEAR Armor does not work after a firmware update
  • Fixes the issue where the satellite fronthaul is down after switching to the 5G channel from the router
Download Link:
https://www.netgear.com/support/product/mk83.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To view your product’s user manual, visit https://www.netgear.com/support/product/MK83.aspx#docs.
Installation Instructions:
Download the firmware to a convenient place such as your desktop.
Be sure to update all MS first, then the MR lastly.
Log in to the router using http://routerlogin.net
 Click the ADVANCED tab.
Click Administration.
Click Router Update.
Click the Manual Update tab.
Select satellite first and a new web page pops up. Please browse the new satellite firmware and upgrade satellite firmware first.
After you finish the satellite firmware upgrade, please find “Locate and select the upgrade file on your disk” on the MR60 web GUI and click “Browse” and locate the file you just downloaded.
Click Upload. While the firmware is loading, do not interrupt the upgrade process.
The router reboots when the upgrade is complete.
After the router boots up and the LED becomes steady blue.
To check that the upgrade was successful, log in to the router again at
http://routerlogin.net and check the firmware version.
NOTE:If a problem is seen after applying this FW update, try powering OFF the ISP modem, MR and MS units for 1 minute then back ON. Last resort would be to try a full on Factory Reset and setup from scratch.
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you in this thread...
Message 1 of 2
Guru
Re: New - MR80 / MS80 Firmware Version 1.1.7.12 Released
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1710 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
