Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
NightHawk MR60 Can't reset to factory setting to re-config main unit.
fernadave
Initiate
My NightHawk MR60 became usuable and I performed a factoty reset. Now I can't login to reset the main MR60.
What did I do:
Using a reset pin I powered down then powered up Nighthawk MR60. Then by holding the reset bottom down for 15 sec's the unit rebooted. After reboot I see a blue light illuminating and using my iPhone I connected to "NETGEAR49" SSID and when asked for password I used the provided password from back of MR60 label. I connected to that network then using Netgear Nighthawk App it requested me to log in using "admin" as the username, and I entered provided password from back side of MR60 unit. The App then returns "Login failed please re-enter correct admin password" .... Now I'm not able to log into Nighthawk to re-configure the unit.
Can someone provide and guidelines or next steps to resolve this issue?
Message 1 of 4
Accepted Solutions
fernadave
Initiate
Re: NightHawk MR60 Can't reset to factory setting to re-config main unit.
Wow, the simple things in life aways get you!!!
Thank you now using the "password" allows my to login using NETGEAR Nighthawk App. Starting to re-configure the main device.
Thank you
Message 3 of 4
All Replies
Guru
the default password should be password
lower case.
Did you try that one?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 4
fernadave
Initiate
Thank you
Message 3 of 4
Guru
glad it was an easy fix Smiley Happy
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 213 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
