Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk AC 2300 - Mesh extender compatibility
Djont
I have a Netgear Nighthawk AC 2300 and I wish to improve my home WiFi coverage with a Mesh Extender product, as I am getting places in the house with poor/no coverage. My home is around 3,800 square feet.
Can anyone recommend a Nighthawk WiFi Mesh Extender that is suitable / compatible with the AC 2300?
Many thanks.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 3
Guru
Re: Nighthawk AC 2300 - Mesh extender compatibility
Pretty much any of netgears mesh extenders would work fine. It all comes down to the specs you want and the coverage you want.
If you think you might need more than 1 extender, I'd look at upgrading to a full mesh system like Orbi or the MK series. I tend to push the triband setups unless you're planning on hardwiring in the satellites.
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 3
Djont
Many thanks for your reply and thoughts... much appreciated.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 712 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
