Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk AX1800 MK62
marjohnd
Follower
I can connect to all my Apple devices but not able to connect with my windows HP computer. It will only connect through the ethernet cable as soon as the cable is taken out I loose the connection.
Message 1 of 3
Guru
Re: Nighthawk AX1800 MK62
In your windows HP computer, what wireless chip is in it and what driver is on it?
Early drivers had issues with AX. Most of them were resolved with driver updates. But those updates rarely get pushed by HP or windows.
so you have to go directly to the manufacturer that makes the wiress chip to get them.
Message 2 of 3
... and, if that fails, what happens when you use the Windows Network troubleshooter?
Message 3 of 3
Discussion stats
  • 2 replies
  • 1027 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
