- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk MR60 and Remote Desktop Connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've seen multiple threads about this subject, but none actually solving it. Here's the situation. We are using this mesh system to replace the ASUS router that was in place previously. With the ASUS router, we had no issues with remotely connecting, but we can't with this router. I can't decide if I've configured it incorrectly or if the built in firewall is blocking everything.
The two computers are listening on ports 3385 and 3386 respectively. Within the office they have static IP addresses. I've set up custom port forwarding services for both of them on the router with the same internal and external port, and identifying the correct internal IP addresses.
Does a firewall block traffic on those ports? If so, how do I turn it off? I don't see anything that addresses this. On WAN setup, I see "Disable Port Scan and DoS Protection," but checking that box did not solve the problem. Should I have used a different port forwarding method?
I'd like to use these mesh routers, but if they simply don't work, I can't.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk MR60 and Remote Desktop Connection
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
Thank you.
