- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Mesh 6 WiFi Router vulnerabiity software update needed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought the Nighthawk Mesh WiFi 6 system AX1800 MK63. The app is telling me that the router is vulnerable and at high risk from cyber threats. They recommend I check for the latest manufacturer software updates. It already did that on its own during the set up plus I've already done that and still there's no change. How do I fix this?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jasm61,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Jasm61,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Mesh 6 WiFi Router vulnerabiity software update needed
Again, thanks for your help 🙂
