- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk Mesh WiFi 6 and 2.4gHz hardware
- Mark as New
- Bookmark
- Subscribe
- Permalink
The "Model" dropdown does not support the Nighthawk Mesh Router MR60 for some reason, I cannot ascertain what it should be.
The firmware is Firmware Version V1.0.6.102_2.0.45 .
I cannot get my 2.4gHz devices to all reliably connect, particularly NEST cameras.
During setup of the router last night, it offered to separate the two frequency radios 2.4gHz and 5gHz. I stupidly allowed the wizard to use the same SSID for both. The install went smoothly and I was able to get the router to see the two MS60s, and get access for my TV and recorder.
Today I went to get the NEST cameras logged in since they didn't link up, and they refuse to. I thought, gee, what I need to do is go through setup again, and give the 2.4gHz SSID a different name, that would let me at least identify what SSID the cameras should TRY to connect to.
I have done the factory reset, but it no longer offers the separate named SSIDs for the two radios. I've ERASED from advanced tab and I've used a paperclip on the reset button for 10 seconds, for 30 seconds, and while it forces me into the Nighthawk phone app to configure logins, the option to rename the SSIDs never shows.
Is there some way I can go back in the setup to identify the 2.4gHz by a different name than the 5gHz?
I finally found the manual online, there is absolutely NO manual in the box, just a card leading me to the Nighthawk app for my phone. Every time I start IT, it forces me to log in as if I was creating a new account - username, password, answer two different questions. Irritating but not fatal.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk Mesh WiFi 6 and 2.4gHz hardware
Hello TexARC,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
