Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk Mesh WiFi 6 system cannot add satellite on wireless network
rbalcon
Tutor
I bought a NETGEAR - Nighthawk MK63 AX1800 Wi-Fi 6 Mesh Router with Two Satellite Extenders. I am trying to add another satelite but cannot add wireless but only using a cable to the router. If I synch using wiresless it gets stuck on the red light.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Accepted Solutions
rbalcon
Tutor
Re: Nighthawk Mesh WiFi 6 system cannot add satellite on wireless network
@plemans seems the fix is to use the synch button using the router app "Add Netgear Satelite" feature and then press the synch button on the satelite harware, at the same time, the satelite then connects and the light turns blue, eventutaly. The only issue is if you unplug the satelite you have to setup the synching again, it wont reconnect automatically.
Message 5 of 6
All Replies
Guru
Try powering off the other 2 satellites that have already been synced. then when the new one syncs, power the others back on.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 6
rbalcon
Tutor
@plemans same result, will only connect when the satelite is wired. I get a red light when I try synching the satelite.
Message 3 of 6
rbalcon
Tutor
@plemans got it working now, after reseting it, moving it away form the router and resynching several times, thx
Message 4 of 6
rbalcon
Tutor
Message 5 of 6
Guru
eitherway, glad to hear you got it working!
If you mark your answer as solved, it might help the next person with that issue (since there's so few on here helping)
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1770 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
