Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk WiFi 6 Mesh System and Metronet Fiber internet
IAFatboy96
Follower
I just switched from Mediacom cable internet to Metronet Fiber internet.  I have good download speeds, but the upload speed is only at 0.07mbps.  If I switch back to Mediacom, the upload and download speeds are above what I am paying for.  Can anyone help me out with this?
My router is the Nighthawk WiFi 6 mesh system (MK63)
The ONT is connected straight to the Internet port on the router.  I have tested with wifi and wired and get the same result.  (If I connect the PC directly to the ONT, I get close to 500 up and down.)
In my searching for possible solutions, I have seen that with Orbi's and Verizon Fios, you have to set the Orbi up as an Access Point.  Anyone know if this will be the same?
Thanks
Message 1 of 2
Guru
Re: Nighthawk WiFi 6 Mesh System and Metronet Fiber internet
What actual ONT is it?
Did you factory reset the router before installing it to metronet?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1274 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
