Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Nighthawk m2 router as satellite?
genisvell
Hello, I didn't see this topic here: can the M2 Nighthawk router be used as a satellite or does it only work as a satellite?
I have to extend my home network (router+satellite are on for now) and can only find router/satellite packs on sale, I cannot find satellites only.
Help !
Message 1 of 3
Accepted Solutions
Guru
Re: Nighthawk m2 router as satellite?
the M2 isn't an orbi device. Its a mobile hotspot. It can't be used as a satellite.
Is this the device you actually mean or what device are you talking about and whats your current setup?
Message 2 of 3
All Replies
Guru
Message 2 of 3
genisvell
Hi, thank you for your reply!
I quite don't know how to write down my setup as you did but I plugged the Nighthawk MK62 router to my Internet box and installed a satellite (still Netgear Nighthawk MK62) to relay the wifi signal in my house (220 m2).
So my problems are:
- I have two Wifi signals in one part of the house and I would like to keep only one, so I will look into how to stop the internet box signal
- I need the wifi signal to be relayed in the second part of the house and would like to know if I need a router+satellite pack or only a satellite to do that.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1309 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
