Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Parental Control on MR60
daveb50golf
Follower
We have an MR60 with two satelites and I like the product.  Overall controls are lacking though.  Can you use the Orbi app to control the MR60?  If so, can you add parrtental controls through the app?
If not, which would be the best comparable Orbi replacement for the MR60 with parental controls?
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Parental Control on MR60
Hello daveb50golf,
The MR60 is not supported by the Orbi app. In terms of parental controls, you may want to check out our RBR50 Orbi system.
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 1389 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
