Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Pls help mk63 connected to my virgin hub3 but not speed I had at the hub before
Lloydie1
Follower
I have a virgin broadband which usually has speeds of 400gbs
I set up the mk63 no problem but when I do speed tests the router is only getting 80/90gbs ??? Any ideas how to fix this . Is it restricted somehow
Message 1 of 2
Guru
Re: Pls help mk63 connected to my virgin hub3 but not speed I had at the hub before
hint: you probably have mbps and not gbps. A bit of a speed difference. 🙂
what virgin gateway is it? Some have their own integrated routers and qos.
have you checked the cable? a 10/100mbps connection from a bad/slower cable can cause issues.
you should be able to check your connection statistics.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 825 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
