- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
QoS
- Mark as New
- Bookmark
- Subscribe
- Permalink
QoS
I have the MR60 Mesh router with 2 MS60 satellites. My issue is with QoS.
I have it enabled, but when I select a device in the list to change the priority, it will open up a different device. Even when I do change the priority, it will remain on whatever setting it was previously on. This seems to be some sort of dynamic QoS function and I'm wondering if I disabled automatic updates to the "performance optimization database" if this will allow me to change priorities manually?
I have performed the typical troubleshooting; different browsers, clear cache, etc., but nothing seems to work. Firmware is up-to-date. I may just disable QoS all together.
Anyone else experience this issue? Support was no help either. Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
Hello scoggnito,
Has support been able to follow up on your case? What firmware version is your system currently on?
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
I chatted with support, but they provided no real help. Just the same troubleshooting I had already performed.
Firmware is v1.0.6.110
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
Hi scoggnito,
May you send me a private message with your email address and case number(s).
Thanks,
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
I'm Having the same issue everytime I click on a specific device it loads another device, i've contacted support but no help from them running Firmware Version V1.0.6.110_2.0.49 on Nighthawk mesh wifi router (MS60)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
NoobNoob,
I would recommend reverting to the firmware version below as we pulled firmware v1.0.6.110.
https://kb.netgear.com/000062202/MR60-MS60-Firmware-Version-1-0-6-102
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
My firmware is V1.0.6.116_2.0.54 and I have the same issue, please help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: QoS
Have you tired reverting FW versions as previously mentioned?
