- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Serial Number on Router different than Serial Number in Registration
- Mark as New
- Bookmark
- Subscribe
- Permalink
I registered my MR60 router. Registration reflects different number than the one on the router and satellites. How can that be? When I failed 3 attempts at password, the registration on the router was not recognized. Really confused as we always refer to the plate on resets. BTW, default password is correct on name plate.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Serial Number on Router different than Serial Number in Registration
Where?
Where were you doing this?
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
