Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Updates Via Nighthawk App
JLRRLJ
I am trying to update my MR60 system via the Nighthawk app on my phone.  It reports the router is up to date, even though it is two versions behind.  I have been trying for over a month.  I will have physical access to perform the updates in about a month.
Seems pretty poor update management, when they don't publish the updates to the App.
Message 1 of 3
Guru
Re: Updates Via Nighthawk App
I recommend you post in the Nighthawk app forum regarding this:
https://community.netgear.com/t5/Nighthawk-App/bd-p/en-home-networking-apps
I recommend that if you want to update and have the means to, manually download the FW files and update the satellites first then router lastly using a wired PC and web browser.
or
If your system IS working, don't fix it. Smiley Wink
Message 2 of 3
JLRRLJ
It's a security update, so it's working don't fix it doesn't cut it.
Message 3 of 3
Discussion stats
  • 2 replies
  • 872 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
