Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Whats the difference between MR6x and MK6x
MetalFatigue
Initiate
I have a MR62, for a couple of years now. Mostly very happy, though a couple of times I had to struggle with it. Recently it just didn't let me connect to it. I think it was a firmware update. Eventually I found a workaround that strangely was wifi password dependent.
As i was researching for issues I came across MK6x which seem the same system even with the same design. Wifi-6, EasyMesh, etc. and both are one of the cheapest WiFi6 mesh you can buy.
Seems that MR6x is not sold anymore and was replaced by MK6x. Is it just a revision or are there changes in features?
Message 1 of 3
Accepted Solutions
Guru
Re: Whats the difference between MR6x and MK6x
MR60 is the router
MS60 is the satellite
MK6* is the both of them together with the * denoting how many router/satellites together. (MK63 is router + 2x satellites for 3 devices)
Message 2 of 3
All Replies
Guru
MR60 is the router
Message 2 of 3
MetalFatigue
Initiate
My bad. You are right. just saw differently in 2 places and I thought it was different things.
Thanks
Message 3 of 3
Discussion stats
  • 2 replies
  • 1139 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
