Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
Why does firmwareupdate fail everytime?MK63
Perege
Tutor
MK63 System
Message 1 of 9
Guru
Re: Why does firmwareupdate fail everytime?MK63
have you tried manually updating it and not automatically?
Nighthawk MK63 | WiFi System | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 9
Perege
Tutor
Yes. And that works fine, but what's the point of having the possibility in the Nighthawk app if it doesn't work?
That's what I mean. 😉
Message 3 of 9
Guru
what modem/gateway is it connected to?
Message 4 of 9
Perege
Tutor
I Have My Router (MR60) Connected To The Fiberbox.
Message 5 of 9
Guru
what fibrebox is it?
Message 6 of 9
Perege
Tutor
Don't See What It Matters, Because It Has Worked Earlier, But This One 😉:
Message 7 of 9
guitarman3001
MK63 System
Exact same thing happens to me.  I had to update it manually through each unit's web interface.  But...the new firmware didn't fix anything for me but it did cause new problems so you may want to hold off updating.
Ultimately, this product is horrible.  Seems like nothing works right on it.  Every firmware update that's supposed to fix a previous problem ends up creating new problems.
And now it's been recommended to me that every time I do a firmware update I may need to do a full factory reset of the system to get it working properly again.
Message 8 of 9
Guru
I see "Gateway" mentioned here:
https://dktcomega.com/products/fttb-ftth-networks/
Though not sure if there is a built in outer at this box or if it's just a Fiber internet box only and no router built in.
Possible there is a NG service issuse while the MR checks the services.
You can always manually update FW:
https://community.netgear.com/t5/Nighthawk-Mesh-System/New-MK6x-series-MR60-MS60-FW-v1-1-6-122-Relea...
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 9 of 9
Discussion stats
  • 8 replies
  • 132 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
