mehmetakalin's avatar
mehmetakalin
WiFi access is not working after power/hydro down and up
Hello,
I have NETGEAR Nighthawk Mesh System WiFi 6 Router and its firmware release is V1.1.6.124_2.0.59 (latest). Wireless appliances (mobile phones, smart bulbs, smart cameras, etc.) cannot able to connect after power/hydro down and up. I reset all Mesh System and I reconfigured. I've got same solution. No connection. I just figured out a temporary solution. It is the changing SSID name to different and the changing it back. After that all devices are connecting successfully.
So, is anybody explain why the problem happens. Is it firmware issue? I appreciate all answers.
Thanks,
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network
    Hope hydro/water wasn't involved here.
    • mehmetakalin's avatar
      mehmetakalin
      Hi FURRYe38,
      Thanks for replying. I did all your suggestions, previously. My NETGEAR Mesh System model is Nighthawk MR60 and it has latest firmware version. I have wired connection with network switch on my LAN, too and any wired device is not being affected when power down and up which means it is not related Internet or WAN connection. I am IT Network Engineer and I am checking every single point of LAN and router. I am using Fiber modem for accessing Internet and my ISP is strong enough to provide Internet connection. This problem is affecting just wireless devices and I have a temporary solution which I explained, previous message. My Mesh System and router's power is supporting by APC power backup unit for protecting spikes, but wireless devices doesn't have. My opinion is a bug on NETGEAR Nighthawk Mesh router's firmware release and it needs to be fixed. I already informed them and am waiting their feedback.
      Thanks again,
