- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
failed firmware update on R6120
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got an email suggesting that I update the firrmware on my R6120.
I opened the Netware Genie on my Windows PC.
I clicked on "Router settings" and logged in.
Then I clicked on "update" and it reports "Failed to get firware version information."
Then I checked the current firmware and see that it is far out of date.
So I used my browser to connect instead.
I downloaded the new firmware and clicked on "upload"
It took a couple minutes, but it uploaded.
Then the router tried to restart. After an hour the power light was still blinking. So I disconnected it and restarted.
Fortunately, it still works with the old firmware (1.0.0.58).
Should I be thankful that the router still works and forget about upgrading the firmware?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: failed firmware update on R6120
what version did you try installing? you're 6 versions behind.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The file I downloaded from Netgear yesterday and tried to install was R6120-V1.0.0.80.img.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to visit the General Routers forum for your model router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
