Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
nighthawk mesh app network map
bigfish
Hi. Am installing a mesh router with two satellites. One is having trouble staying connected, and so while trying this and that, I have gotten it so that both satellites are called Satellite-1. Both of them seem to be working (at least right now), but how can I get them to have different names? A re-setup doesn't seem to do it. Thanks.
Message 1 of 4
Accepted Solutions
knightz01
Apprentice
Re: nighthawk mesh app network map
Hi bigfish,
To change the names of the Satellites
1) Open Nighthawk app / click network map / click on the satellite you want to name change / click details / edit Satellite name
Kev
Message 3 of 4
All Replies
Christian_R
NETGEAR Employee Retired
Hi bigfish,
If you recently purchased the device, I would recommend contacting our support team to assist with getting your device installed. You may contact support by using the link below.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 4
knightz01
Apprentice
Hi bigfish,
Kev
Message 3 of 4
bigfish
Thanks. I did eventually get it straightened out.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4346 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
