Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
nighthawk mesh wifi 6 router MR60 no internet connection error
VyperDD
Follower
Trying to set up the nighthawk mesh router. Router is detected but keep getting No Internet Connection error. Have done the suggested unplug modem and plug it back in but still getting error.
Ethernet cable is connected correctly (internet port on router & LAN1 on modem).
Not sure what to do next to resolve error
Message 1 of 3
Guru
Re: nighthawk mesh wifi 6 router MR60 no internet connection error
What modem are you connecting it to?
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
You have posted your message in the section of this community given over to Mobile Routers, Hotspots & Modems. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
I will ask the Netgear moderator to move your message.
You could also visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1060 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
