Nighthawk Mesh WiFi
Welcome to the Nighthawk Mesh Community
Advanced Whole Home WiFi Click to Buy Nighthawk Mesh WiFi 6
Reply
using 2 mk63 mr60s wired together
Fusionjoker
Follower
Is there a way I can have both my mr60s wired together via ethernet, have 1 plugged into my internet provider and have the same sygnal given off both routers and points creating a single uniform network. if so how would I go about setting it up? (I already have 1 mk63 system set up and trying to add the second one)
Message 1 of 2
Larry101
Star
Re: using 2 mk63 mr60s wired together
Yes, You can set up the second router in bridge (AP) mode.
https://kb.netgear.com/24105/What-is-bridge-mode-and-how-do-I-set-it-up-on-my-Nighthawk-router
HTH
Model: Dual Band
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1178 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
