dilloninmn's avatar
May 05, 2022
2 WiFI extenders Login
If I setup 2 extenders is the house how do I login into them? It would appear that the same url is used for all wifi extenders.
  • You can use the ip address from them. Log into your router and find the ip address for each.
    You'll be able to use that to log into them.
    Fyi, I highly recommend when using more than 1 extender to not daisy chain them.
    Daisy chain: router---->extender----->extender
    Set them up in star configuration for best results:
    Star: extender<--------router-------->extender
  • plemans's avatar
    • dilloninmn's avatar
      dilloninmn
      Tutor
      Bingo that worked perfectly thanks. And no I’m not daisy chaining them. These extenders are on the opposite ends of the house one in the garage one on the deck to allow for better coverage in those areas.
      Curiosity question shouldn’t both extenders show up in my network map? There’s only one that showing up.
      • plemans's avatar
        Should it? yes.
        Does the app always work as it should? more doubtful.
        Usually when people are needing more than 1 extender, we recommend moving to a mesh system both because of performance and ease of use. When using more than 1, many times you need to use its ip address to log directly into the one you want.
