Orbi WiFi 7 RBE973
Reply
4AMH097EA7224
3oneswest
Follower
4AMH097EA7224
TRYING TO PERFORM A FIRMWARE UPGRADE AND ERROR MESSAGE STATES THAT I CAN NOT CONNECT TO THE MYWIFIEXT GENIE TO LOGIN AN PERFORM THE REQUIRED MAINTNANCE. I WAS ABLE TO SELECT THE ZIP FILE AND DOWNLOAD TO MY DESKTOP..
Model: EX3700|AC750 WiFi Range Extender Essentials Edition
Message 1 of 2
Guru
Re: 4AMH097EA7224
1. Caps lock. to the left of the "a" key. thanks
2. Have you tried logging into the extender using the ip address the router assigned to it? This tends to go smoother.
3. make sure you extract the downloaded zip file before attempting to update.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1111 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
