Peterm38's avatar
Peterm38
Follower
Sep 03, 2017
AC1200 EX6150v2 WiFi Range Extender connection problems
I have a AC1200 Model EX6150v2 WiFi extender which has been working OK for the past 4 weeks connected to Surface laptop/tablet, Sony Smart TV and Samsung Note3. Connection lost for no reason 2 days ago. Have reset extender and strong signal showing (as previously). When I input Security Code comes up with secured but no internet on Surface and TV but OK on phone. Have checked internet service and modem with ISP - all good and no recent firmware updates etc. Message on TV is :failed - plse refer to the instruction manual supplied by your ISP. and retry Network Setup after configuring the Acct Settings PPPoE of your modem. Reluctant to make any changes as nothing has changed except extender stopped working and shows same strong signal as previously. Any help appreciated - Thanx
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Peterm38
    Have you tried to remove the network in the wireless setting of the surface?
    DarrenM
