WIFIstuff's avatar
WIFIstuff
Follower
Aug 29, 2022
AC750 WIFI Extender
Is it possible to have 2 AC750 WIFI extenders working on opposite ends of the house?  Talked with Tech Support and could not findd a resolution.
1 Reply
  • plemans's avatar
    You can.
    1. what model do you have? AC750 is a speed
    2. what router are you connecting it to?
    3. what method of setup are you trying to use? (wps, the app, installation assistant)
    4. where are you running into issues? (details help)
