Orbi WiFi 7 RBE973
Reply
AX1800 4 Can not join network "NETGEAR_EXT"
noelR
Follower
Message 1 of 2
Guru
Re: AX1800 4 Can not join network "NETGEAR_EXT"
What router do you have?
What extender do you have? (hint: ax1800 is a speed, not a model)
go to netgear.com/support/  type in your model number. it'll take you to guides, manuals, firmware, etc.
Are you setting up via wps or using the installation assistant?
Have you tried hardwiring in for setup? It tends to go faster/smoother than doing over wireless or the app.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 467 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
