Orbi WiFi 7 RBE973
Reply
AX1800
KateDay
Follower
AX1800
I have a red led for router link what does this mean? Should I do something to change from red to green?   Thanks.
Message 1 of 2
Guru
Re: AX1800
Well you gave us not much to go off.
What router do you have? AX1800 is a speed, not a model.
What firmware is on it?
What modem/gateway is it connected to?
Is it working?
Have you checked in the manual? They go over what each led light signifies.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 542 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
