Gregavi's avatar
Gregavi
Accessing Access Point
Hi,
I have a WPN802 Access Point that I am trying to setup with password etc. As my main router, I use an 'Ubiquiti Ultra-Long Range WiFi Router PowerAPN'. I have tried to access the AP by connecting it to my network and by connecting it directly to my main router with the address https://192.168.0.231, which is the address on the bottom of the AP. I have also tried connecting it directly to my Laptop. I have also tried http://192.168.0.227, another address I read that I should use.
"This webpage is not available" is the response I keep getting.
Any help is appreciated.
Thanks in advance.
  • if your network is 192.168.0.x subnet and should reach
    I would reset the unit and try again
    I have reset the unit several times with no change in result.
