- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
After Install of EX7500 I do not have the 2.5 or 5.0 Networks in my listing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
After installing the EX7500 by following the instructions that came with the device I do not have the new networks 2.4 or 5.0 in my network listings. All the lights are on the extender. If i try to go to the NETGEAR_EXT it says not connected. Don't see any improvement in network speed so I think something is not configured correctly. I have Comcast X1. I have restarted my Router several times with no improvement.
Hoping someone in the community had this issue and found a resolution.
Thanks for any help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: After Install of EX7500 I do not have the 2.5 or 5.0 Networks in my listing?
If you log into the comcast router, does the extender show in its connected devices page?
Did you setup the EX7500 using wps? If so, it sets up using mesh mode by default. Meaning it has the same ssid as the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, looking into it now.
I would like to have the 2 networks show up so I know which is connected. Can I do that?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is it possible to turn off the mesh setting when in setup? Will it create the 2 networks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can disable that. Its under Onewifi in the extenders settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the info. Now my 2 networks show and i can connect but im getting a "Weak Security" Message for both. My original Network does not show this error. What do i need to do to get a stronger security? I tried to change it to a WPA3 as it says in the instructions but I do not have that selection. My X1 Xfinity router is only 2 weeks old. I it a setting within the extender settings?
Thanks for any assistence.
- Mark as New
- Bookmark
- Subscribe
- Permalink
WPA3 is a hardware change. The AC versions don't have it.
the notice is a recent implementation of notifying people of weaker security but for the most part, wpa2 is still in use by the majority
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
