Orbi WiFi 7 RBE973
Reply
Can I use my 5ghz channel over the extender?
gresch
My Netgear 6100 router has 2.5 and 5 ghz channels. I'm using a WN3000 rpv3 extender to reach a difficult area. My current setup sends only the 2.5 ghz channel to the remote area. Can I "attach" the extender to the 5 ghz channel, or is that beyond its capability? How do I make that change in the router or the extender (if I can)?
Model: WN3000RPv3|N300 WiFi Range Extender
Message 1 of 2
jvasanth1984
Virtuoso
Re: Can I use my 5ghz channel over the extender?
Hi @gresch,
                    Your extender is a single band where it doesn't have 5GHz capability. If you are concerned about 5GHz, you may look for dual band extenders which can help you to extend both 2.4 and 5GHz of your R6100 router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3730 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
