- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot connect to 5Ghz EX6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm having a problem connecting to 5Ghx. It's stars scanning a 2.4Ghz and there is a tab that says "Skip to 5Ghz Networks" but when a try to activate this tab, it restarts a 2.4Ghz search. I've reinstalled the Nighthawk app and reset the extender, but this didn't resolve the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Cannot connect to 5Ghz EX6400
where are you seeing this? In the setup page?
Did you try a different device?
Or where are you seeing this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Screen says, "Select an existing 2.4Ghz network". It can't connect to it. There is a tab that says, "Skip to 5Ghz networks". When I tap on it, goes back to the 2.4Ghz scan.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what router are you connecting it to?
Did you try the installation assistant and not the app?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know what make router as it's supplied by my apartment complex. Besides the cellphone app, I've tried to use the.computer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess nobody can help me with this problem. So, I will return it.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
