Orbi WiFi 7 RBE973
Reply
Change range extender (WN100RP) to new router
debthack
Have recently switched to new fibre broadband, so have new router. I can't get Netgear WN100RP to pick it up. It still thinks it is on the old network.
How do I change this?
Thanks
Message 1 of 5
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Change range extender (WN100RP) to new router
Hello debthack
Make sure your are holding down the wps for 5 or more seconds when trying to connect with WPS.
DarrenM
Message 4 of 5
All Replies
DarrenM
Hello debthack
you can try to do a factory reset on the extender and try to set it back up also have you tried to use WPS to connect to the new router.
DarrenM
Message 2 of 5
debthack
Hi, I've tried both ot those, but no luck so far.
Message 3 of 5
DarrenM
Hello debthack
DarrenM
Message 4 of 5
debthack
That worked! Thank you
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 4396 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
