Orbi WiFi 7 RBE973
Reply
Changing channel on EX2700 Extender
ronlhur
Is there a way to set the channel directly on the EX2700 so that its different than the router? It appears that I am getting interferrance when using the same channel between the router and the Ex2700. Using a WiFi tester I can see clear channels until I change the router (and the 2700) to the indicated clear channel, its no longer clear and other channel is now clear.
Thanks
Model: EX2700|N300 WiFi Range Extender
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Changing channel on EX2700 Extender
Hello ronlhur
no way to do this as the extender follows the channel that the router is using.
DarrenM
Message 2 of 4
ronlhur
Thanks, then is there any way to reduce the channel interferrence caused by the use of the same channel? Again, I see clear channels on an analyzer until the channels are assigned to those channels.
Message 3 of 4
DarrenM
Hello ronlhur
As long as just your devices are on that channel it should be fine just stay away from channels that your neighbors wifi are on.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4681 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
