Orbi WiFi 7 RBE973
Reply
EX2700 password
WillB
Tutor
EX2700 password
Hi there,
I have searched around on this page and others to find a seeminly common issue of trying to connect a wifi extender to the network. I have undergone factory reset; linked the extender to the router and everything works perfectly until the password is not accepted when trying to connect a device to the wifi network (xxx_EXT). Solutions previously provided include logging onto mywifiext, but this doesn't work if I can't log into the extender. Can someone please help?
Message 1 of 8
Accepted Solutions
Guru
Re: EX2700 password
Does it connect? Or is it asking for the wireless password?
When its in factory settings, it shouldn't ask for a password for the wireless.
It should only ask if its been setup or wps has been used prior.
So try the factory reset option.
You could also connect a pc/laptop to it via the ethernet port for setup. Just make sure to disable the wifi on the pc/laptop you use (if you do) so it doesnt' default back to that connection during setup.
Message 6 of 8
All Replies
Guru
Re: EX2700 password
Did you try factory resetting the extender (push and hold reset for 7-15 seconds while powered on) and then using the installation assistant? don't use wps for setup.
What firmware are you on?
What router are you connecting it to?
Message 2 of 8
WillB
Tutor
Re: EX2700 password
I'm using the latest Vodafone hub with fibre. Can you pls advise me how I use the Installation assistant?
Message 3 of 8
WillB
Tutor
Re: EX2700 password
P.S. And yes...I have done the factory reset for 15 seconds.
Message 4 of 8
WillB
Tutor
Re: EX2700 password
Sorry - and finally, I understand that the installation assistant requires connecting to the extender on a device, but I can't do this because every time I try to connect it asks for the password. What am I missing?
Message 5 of 8
Guru
Re: EX2700 password
Message 6 of 8
WillB
Tutor
Re: EX2700 password
boom! it worked. thankyou. very basic mistake - not pressing factory reset for long enough.
Message 7 of 8
Guru
Re: EX2700 password
Glad it worked!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 6158 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
