Orbi WiFi 7 RBE973
Reply
EX6120 Password Issues
Richard001
Hi,
My extender connects to the router and I have a green light, however when I try to connect my laptop, having tried 2no. of them, it says the WiFi Network Key is incorrect. Its is the same one used to connect the extender to the router. So I dont understand.
Thanks
Model: EX6120|AC1200 Dual Band WiFi Range Extender
Message 1 of 4
Guru
Re: EX6120 Password Issues
What router are you connecting it to?
did you install the extender using WPS (push button) or using the installation assistant?
Message 2 of 4
mikeote
Hello @Richard001
Password protection will prevent unauthorized access to your EX6000 or EX6120 user interface. By default, password protection is enabled but you can also disable it to allow access to the user interface without typing your login credentials.
Read More - https://kb.netgear.com/30088/How-to-turn-off-or-on-EX6000-EX6120-password-protection
Message 3 of 4
Richard001
Hi, I sorted it thanks. Router was connected to extender via WPS, so I tried the same with the laptop to the extender and it worked.
Thanks
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 793 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
