Orbi WiFi 7 RBE973
Reply
Ex3700 tire of nothing workingas it should
Jbull63
Follower
Im really getting tired of getting these wifi extenders that seem like they connect to the wifi router but dont actually connect. Im to the point now that i dont care if it is new or used if some one could set it up to something to make sure it will work before i get it.
Message 1 of 2
Guru
Re: Ex3700 tire of nothing workingas it should
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 456 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
