Orbi WiFi 7 RBE973
Reply
Firmware update fail on EX6200
jelrsl
Hi, I am having trouble with updating the firmware, following the Genie online and also downloading from the Netgear website, both ways fail to update the firmware
  • Hardware Version EX6200
  • Current Firmware Version V1.0.3.82_1.1.117
  • New firmware version 1.0.3.90_1.1.125
both ways ends in the same failure, stating invalid Firmware.
i have tried on multiple web browers and through the mobile app,none are successful.
The Genie app on android is no longer compatible and I cannot seem to find the EX6200 on the nighthawk app.  The username is locked "admin" to the Router R6260, and i cannot change to the username to the EX6200.
Any help appreciated
Model: EX6200|AC1200 Dual Band WiFi Range Extender
Message 1 of 8
Guru
Re: Firmware update fail on EX6200
There's a .94 version actually posted now.
When you download the file to manually install it, are you unzipping it?
Some just click on it to open it.
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Message 2 of 8
jelrsl
thanks for the quick reply, however i tried and it failed
Firmware upgrade failed. Please check your file.
I downloaded and extracted the file to use only the EX6200-V1.0.3.94_1.1.128.chk.
any other suggestions?
Message 3 of 8
Guru
have you tried a factory reset?
Are you on windows or mac?
Message 4 of 8
jelrsl
Factory reset has been done, and I am running Windows. I tried to use different browsers too. But that didn't work either.
Message 5 of 8
jelrsl
I am also connected both too WiFi and Ethernet directly to the device. Not sure if that could be a factor as well?
Message 6 of 8
Guru
Look at the label on it, which version is it? the firmware matches version 2 but I just want to make sure.
Have you tried a different device.
Message 7 of 8
jelrsl
I don't think it is V2 as no indication on the back. Also the V2 firmware available for download don't match the sequence. I tried anyhow to update the firmware for V2 and it failed as well.
I have logged in through my android phone and tried auto update and also to link the file, and still failed.
I think I have run out of options
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1430 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
