Darbuka
Sep 17, 2021Aspirant
Hardwire from Nighthawk Mesh Router to Nighthawk ax6000 extender
I have just purchased an EX8 8 stream wifi mech extender ax6000. I would like to hard wire it from my Nighthawk Mesh router.
Is this doable, and how would I proceed? I need to hard wire because my room has metal and plaster walls, and acts like a faraday room. I have a satellite in my room, but it does not help. I get 400 by the router and 10-15 in the room.
1 Reply
Yes you can hardwire it in.
Just connect it via cable and then re-run setup and set it up in access point mode and not extender mode.
