Orbi WiFi 7 RBE973
Reply
How do I bypass the genie on a WN2500RP
itsstockiswear
Follower
I have a firewall in place and I run a tight ship as far as IP's go.  I purchased this extender to extend the wireless coverage in my house from a netgear router that my firewall uses as a wireless access point.  Whenever I go to config the extender, instead of the standard admin menu, I'm presented with some kind of genie.  I do not see a way to bypass it at all.  Since I can not set the extenders static IP and related specs, as soon as the genie completes the extended network fails.  I then cannot even log back into the extender.  I have tried this with both a wired and wireless connection.  Permissions are set in my firewall for the extender's mac and it's ready to roll on the back end.  I just can't get to the admin menu on the extender.  I have read in this forum that a direct connection (doesn't work) or completing the install (I can't complete the install) and re-accessing the extender allows access to settings.  My firewall is a PFSense box.  Before I go through the trouble of creating rules or taking down parts of my firewall to make this thing work, I wanted to make sure I wasn't overlooking anything.  Thank you for your time,
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: How do I bypass the genie on a WN2500RP
Hello isstockiswear
there is not a way to disable the genie on this device.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3725 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
