- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I change the network name of an extender EX2700?
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I change the network name of an extender EX2700? I do not know the IP address, and cannot connect to the Netgear setup via the "my wifi ext dot net" address.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I change the network name of an extender EX2700?
You'll need to log into your router and find its attached devices page (or equivelent).
From there it should have the extenders IP address that you can log into it with
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, but I don't know how to log into my router. I've gone through the instruciton manual several times, and can't figure it out. I cannot access the router via wifi, and I've tried all of the urls as instructed in the manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MissMick wrote:Thank you, but I don't know how to log into my router.----I would have no idea as you haven't even said what model router you have.
I've gone through the instruciton manual several times, and can't figure it out.---manual for the extender? For the router? what router is it? is it supplied by an Isp? is it a 3rd party device? I cannot access the router via wifi,-----that'd be a router issue and not an extender issue. I'd try getting your router functioning first and figure out how everything works on it before adding devices to it. and I've tried all of the urls as instructed in the manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Netgear C6250 router. It is functioning perfectly well. I am always referring to the manuals that came with the extender and the router.
My original desire was to simply change the name of one of my extenders, EX2700, but I can't even access the Netetgear genie to do this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
use the browser and go to 192.168.100.1
that'll get you to the c6250
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. But as I've already mentioned, NONE of the usual urls works for me—not any version of this this, not routerlogin.net, not mywifi.net or mywifi.com. None of them work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The address 192.168.100.1 finally did take me to the router sign-in! After some muddling around and resetting of devices, I finally was able to perform the task I originally wanted to—simply changing the extender's name.
Thank you for your patience and continuing to hang in there with me to fix this!
- Mark as New
- Bookmark
- Subscribe
- Permalink
glad it worked!
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
